russcron
Aug 29, 2017Aspirant
Seemingly Erroneous Speedtest Result
Hi Folks, This is a new install with Netgear DM200 DSL modem on Frontier Communications. Orbi SW was upgraded to latest. My normal speedtest results are 5M down and .7M up with my old hardware....
DarrenM
Aug 30, 2017Sr. NETGEAR Moderator
Hello Russcron
What cameras do you have?
DarrenM
- russcronSep 01, 2017Aspirant
Hi Darren,
Thanks for the contact.
Not working:
Logitech Alert
Arlo
Samsung Smartcam
Working:
Lorex Ping 2 Series
-Russ
- DarrenMSep 01, 2017Sr. NETGEAR Moderator
You may need to disable the DHCP server on the DM200 page 62 should help.
http://www.downloads.netgear.com/files/GDC/DM200/DM200_UM_EN.pdf
DarrenM
Thanks. I tried to set it up in 'modem only' mode but will check to see if I was successful.
Will let you know.
Russ
No such luck. The Netgear DM200 DSL modem was in modem only mode.
I cross checked the DSL, WAN, LAN and Internet settings in the DM200 & Orbi against my Netgear D6200 DSL modem/router and found no differences.
My AT&T Microcell does not work either.
Had to revert to the D6200.
