pdolmsted's avatar
Mar 16, 2021
Selectively shut out of wifi system
I have a very strange problem.
RBK43S system with router and two satellites.
Modem: Netgear CM1000
Internet: Xfinity/Comcast
1. I needed to reboot the router a few times.
2. Thus, finally succumbed to upgrading to RBR40 2.6.2.104, RBS20 2.6.2.104.
3. That seemed to work for a while. But then it didn't, and we needed to reboot even more frequently. So following some of the discussion on the boards with some sort of chaos with the .104 fimware, I downgraded backto RBR40 2.6.1.23 and RBS20 2.6.1.38.
4. Now the following is happening:
- I cannot attach on my phone, laptop, or desktop.
- My wife can attach using her phone, desktop, laptop and tablets and has no problem.
?????? How can it work for one user but not another user, and on all devices respectively? Our DNS settings are the same [we're on the Mac ecosystem]. Is there some hidden place where I could be blacklisted?
The Orbi admin password also seems to have changed as well, so all h*** has broken loose. I can't log in again to reset the password even when entering the serial number and the answers to the challenge questions [tried two different browsers in case the caches were acting up].
Have I been hacked? Should I start again from scratch? [whatever scratch may be].
Very very strange and any advice is very welcome!
    • FURRYe38's avatar
      Opps sorry I saw your modem brand and model. :smileyembarrassed:
    • pdolmsted's avatar
      pdolmsted
      Tutor
      Info already provided: Netgear CM1000 [not from the ISP]
      2500
      What is the distance between the router and satellite(s)?
      around 30 feet, but this isn't the issue. It doesnt' work for me even when hard-wired into the router. Neither my wife or I are in range of or using the satellites.
      https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
      There is no recommendation to do this from Netgear. I don't want to do this but will try it if good reasons given. This can't explain the selective nature of shutting one person out, can it?
      • FURRYe38's avatar
        Yes. A reset would be needed to clear out any odd problems as a troubleshooting step.
