Airic04's avatar
Airic04
Initiate
Oct 03, 2018
Separate 2.4GHz and 5GHz- Orbi RBR50
Hi Community,
I have an Orbi RBR50 and Satellite. I recently bought a new appliance that is WIFI compatible but only with 2.4GHz wifi. I went into my advanced settings on my Orbi router and made sure that both 2.4 and 5GHz were checked and active. I tried going through the app of the appliance to connect it to my wifi network but it was unsuccessful. I am not sure how to make it connect to my wifi which only has "one" SSID name even though it's supposed to be both 2.4 and 5GHz. Is there a way to make a 2.4GHz network separately? Any advice would be great, thank you!
  • FURRYe38's avatar
    The Orbi is designed only to run on a single SSID between 2.4 and 5Ghz.
    If the device is only compatible with 2.4Ghz, then it won't try to connect to 5Ghz.
    Try setting the Orbi security mode to disable temporarily. Then see if the device will connect. Then set WPA and TPIK on the Orbi router. Then again try the device. Then try WPA2 and AES for the best security measure. See if the device connects.
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    What firmware version is loaded on the Orbi?
    What is this appliance device? Mfr and model?
    • Airic04's avatar
      Airic04
      Initiate
      Hi FURRYe38, thank you very much for responding. Unfortunately, I have tried all your suggestions and so far I cannot get it to connect.
      I bought a Whirpool Cabrio Smart Washer and Dryer. I downloaded the Whirpool app, and it auto-detects my iPhone's WIFI network (so there is no dropdown or list to choose from within the app) and asks for my WIFI password. It tries to connect the washer or dryer to my WIFI but I get an error message that it cannot connect to the router.
      My firmware on my Orbi is: Router Firmware Version V2.2.1.210.
      The Whirpool:
      Cabrio Washer Model# is: WTW8700EC and the Dryer is: Whirpool Cabrio Dryer Model #: WED8700EC
      • FURRYe38's avatar
        So when you set the Orbi's wifi security to disable, the devices would not see or connect to the Orbi wifi? If so, then I would contact Whirlpool about this and ask them for help and information. Let them know that you've tried the Orbi with no wifi security and with security enabled and the units would not connect. Ask them if there is any known problems with there devices connecting to NG Orbi systems...
