sclawrenc
Sep 30, 2019Apprentice
Separate WiFi 2.4 and 5ghz bands
I am no longer able to separate my WiFi bands on the most recent Orbi firmware versions. It worked for over a year fine, but after updating firmware they are no longer separate. I have tried the Te...
Mar 10, 2020Guru - Experienced User
I agree as well. Since Smart Connect same out years ago, this has been problematic for everyone router mfr and device mfrs. Before it was easy, you set either frequency to a different SSID and you told the device which one to connect too. Now it's all automatic. I'm sure it's a hassle for the chipset mfrs on both sides of the fence let alone the router mfr who integrate and test all this.
theoak
Mar 11, 2020Luminary
So wild idea ... there are a few custom modified firmwares out there even based off of 2.5.1.8. You can Google for them. If your Orbi is out of warrant/support and you are brave, maybe these custom firmwares open up the features you are looking for? Of course Netgear is going to say "no no no". Additionally, you can brick your device along the way. Using custom firmwares is definitely an advanced advanced skill set. Do so at your own risk.
- DeihmosMar 11, 2020Guide
After all these years and so many complaints it is amazing Netgear hasn't added an option to seperate the ssid.
- FURRYe38Mar 11, 2020Guru - Experienced User
For those who want to try 3rd party FW for the Orbi 50 series only, can find it here:
This is only for the 50 series Orbi. Other Orbi models are not supported.
NG hasn't made any separation of SSIDs official. Even with Orbi AX, its' still not support. Users have been asking about this for a long time and NG doesn't seem to want to give in. User can temporarily disable SSIDs for either frequency however which does help get 2.4Ghz devices connected. No need to have separate SSIDs. This is a 2.4Ghz device Mfr setup software problem and not NG Orbi issue however.
Good Luck.
- mrshadesMar 11, 2020Guide
^^^ I've just been bitten by the "Can't get 5GHz network SSID to change permanently" problem - and having looked into the NG firmware, it's pretty obvious that they are going out of their way to stop this happening, and even if different SSIDs are detected on a running router then it'll revert back to the 2.4GHz one. It's not just that it doesn't survive a reboot (I could cope with that) but it doesn't survive for more than about 5 minutes.
So - I've just said "sod it" and gone with the Voxel firmware.... based on the latest NG firmware, and even looks'n'feels the same. I've updated my satellites and then my router - and it's all good. Working very well.
and YES - I can change the 5GHz SSID to something different, and it sticks.
Thanks Voxel.... boo hiss to NG.
- Retired_MemberMar 11, 2020
Deihmos wrote:After all these years and so many complaints it is amazing Netgear hasn't added an option to seperate the ssid.
Of the other router manufacturers offering a true mesh system, how many provide an option to separate the SSIDs?
- theoakMar 11, 2020Luminary
mrshades wrote:^^^ I've just been bitten by the "Can't get 5GHz network SSID to change permanently" problem - and having looked into the NG firmware, it's pretty obvious that they are going out of their way to stop this happening, and even if different SSIDs are detected on a running router then it'll revert back to the 2.4GHz one. It's not just that it doesn't survive a reboot (I could cope with that) but it doesn't survive for more than about 5 minutes.
Ug ... now you have tempted me :)
Thanks a lot :)
...whilst I don't wish to worry you - after running on it all day (for about the last 7 hours or so) I did just have a catastrophic network failure...
I have multiple devices connecting me to the Internet - Virgin Media hub (in modem mode), to an Asus AC68U (in router mode but with wifi off, providing various extra functions that the Orbi doesn't have or is rubbish at - parental control, OpenVPN server, etc.) and then the Orbi RBR50 (and two satellites) in AP mode. There's a gigabit switch or two in the mix as well...
Anyway - whilst I could see both 2.4GHz and 5Ghz networks, the Orbi IOS app couldn't connect, I couldn't ping anything, zip - rebooted the Orbi and it all started working again.
I did notice some strange things happening before I lost access completely - as I was trying to watch various YouTube videos, which were loading with a black screen and text across the top saying "We're having some difficulty playing this video right now - come back later" (or something like that) - but if I left it for about 30s then the video would start. I'm guessing the Orbi was throwing a huge amount of jabbering packets out or something equally noisy.
Might have been a one off... but a little nervous now!
What is the Mfr and model# of the ethernet switch in the configuration?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925Has a factory reset and setup from scratch been performed since last FW update?
mrshades wrote:...whilst I don't wish to worry you - after running on it all day (for about the last 7 hours or so) I did just have a catastrophic network failure...
FURRYe38 wrote:What Firmware version is currently loaded?
These questions were asked back in message 4.
There has been some chatter on switches with an Orbi. I am not sure if that applies here. Apparently the Orbi needs a pretty "dumb" switch. If the switch is managed and green, it can give the Orbi grief. Perhaps others here can comment more. Perhaps you are already familar with the topic.
Managed switches will work if users disable all IGMP protocols and any green ethernet features. For some non managed switches, green ethernet can't be disabled if present so users would need to find a non managed switch with out is preferred.
theoak wrote:There has been some chatter on switches with an Orbi. I am not sure if that applies here. Apparently the Orbi needs a pretty "dumb" switch. If the switch is managed and green, it can give the Orbi grief. Perhaps others here can comment more. Perhaps you are already familar with the topic.
