sclawrenc
Sep 30, 2019Apprentice
Separate WiFi 2.4 and 5ghz bands
I am no longer able to separate my WiFi bands on the most recent Orbi firmware versions. It worked for over a year fine, but after updating firmware they are no longer separate. I have tried the Te...
Mar 11, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
mrshades wrote:...whilst I don't wish to worry you - after running on it all day (for about the last 7 hours or so) I did just have a catastrophic network failure...
I have multiple devices connecting me to the Internet - Virgin Media hub (in modem mode), to an Asus AC68U (in router mode but with wifi off, providing various extra functions that the Orbi doesn't have or is rubbish at - parental control, OpenVPN server, etc.) and then the Orbi RBR50 (and two satellites) in AP mode. There's a gigabit switch or two in the mix as well...
Anyway - whilst I could see both 2.4GHz and 5Ghz networks, the Orbi IOS app couldn't connect, I couldn't ping anything, zip - rebooted the Orbi and it all started working again.
I did notice some strange things happening before I lost access completely - as I was trying to watch various YouTube videos, which were loading with a black screen and text across the top saying "We're having some difficulty playing this video right now - come back later" (or something like that) - but if I left it for about 30s then the video would start. I'm guessing the Orbi was throwing a huge amount of jabbering packets out or something equally noisy.
Might have been a one off... but a little nervous now!
Retired_Member
Mar 11, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
These questions were asked back in message 4.
