DaveK1950
Feb 18, 2018Aspirant
Setting a different range of IP addresses
I'm about to set up my Orbi system, but the standard range of IP addresses is going to cause me much work. The router I currently use assigns IP addresses in the range 192.168.254.xxx, while the Orb...
Roamabout
Feb 18, 2018Luminary
The Orbi router when used in Router mode and as a DHCP server has pretty much the standard controls for address assignment. You can set the range for what DHCP will use as well as assign IP addresses to specific devices. It is all on the Advanced.. Setup.. Lan Setup.. tab.
HypnosFred
Jun 29, 2018Initiate
UPDATE: Nevermind, found it. Ignore this post (I would delete it but there doesn't appear to be a way to do that).
I have the latest firmware (V2.1.4.16), but there is no "Lan Setup" on the Advanced setup page, so there appears to be no way to set the DHCP range. Anybody else seeing this? Am I missing something??
-Fred
- FURRYe38Jun 29, 2018Guru - Experienced User
There is LAN setup under Advanced Tab...
Glad you found it. :smileywink:
- DaveK1950Jun 29, 2018Aspirant
I think I ran into the same issue when I initially set the system up. I think I forgot to check the box that set the Orbi as a DHCP server, but once the box was checked I was able to see the DHCP address range option.
- FURRYe38Jul 02, 2018Guru - Experienced User
:smileywink:
- CrimpOnJul 22, 2018Guru - Experienced User
On the Advanced Tab, select "Setup", and "LAN Setup" is one of the choices under it.
