DaveK1950
Feb 18, 2018Aspirant
Setting a different range of IP addresses
I'm about to set up my Orbi system, but the standard range of IP addresses is going to cause me much work. The router I currently use assigns IP addresses in the range 192.168.254.xxx, while the Orb...
HypnosFred
Jun 29, 2018Initiate
UPDATE: Nevermind, found it. Ignore this post (I would delete it but there doesn't appear to be a way to do that).
I have the latest firmware (V2.1.4.16), but there is no "Lan Setup" on the Advanced setup page, so there appears to be no way to set the DHCP range. Anybody else seeing this? Am I missing something??
-Fred
Jun 29, 2018Guru - Experienced User
There is LAN setup under Advanced Tab...
Glad you found it. :smileywink:
