DaveK1950
Feb 19, 2018Aspirant
Setting a different range of IP addresses
I'm about to set up my Orbi system, but the standard range of IP addresses is going to cause me much work. The router I currently use assigns IP addresses in the range 192.168.254.xxx, while the Orb...
HypnosFred
Jun 29, 2018Initiate
UPDATE: Nevermind, found it. Ignore this post (I would delete it but there doesn't appear to be a way to do that).
I have the latest firmware (V2.1.4.16), but there is no "Lan Setup" on the Advanced setup page, so there appears to be no way to set the DHCP range. Anybody else seeing this? Am I missing something??
-Fred
DaveK1950
Jun 29, 2018Aspirant
I think I ran into the same issue when I initially set the system up. I think I forgot to check the box that set the Orbi as a DHCP server, but once the box was checked I was able to see the DHCP address range option.
- FURRYe38Jul 02, 2018Guru - Experienced User
:smileywink:
