IainMcFarlane
May 07, 2020Star
Setting up Orbi backhaul
Hi all I have just bought the triple pack Orbi as my current Wi-fi is struggling to cope with demand. I am looking for advice on the configuration of backhaul I have planned. I had hoped to connect...
May 07, 2020Guru - Experienced User
Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure you connect any RBS wired to the back of the RBR directly or thru a switch. You can't connect the RBR and RBS in parallel to a switch infront of the RBR as the status reporting of the RBS will not work on the RBR. Any wired RBS needs to be serially connected behind the RBR.
Yes if you can directly connect the RBS to the back of the RBR, you can hang a switch of the back of the wired RBS.
I would disable Daisy Chain on the RBR as well.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
IainMcFarlane
May 08, 2020Star
Hi again
reading first articles I think setting up the Orbi in AP mode may be the safest way forward, is there any real disadvantage over performance with this ?
