TLI-mark
Mar 01, 2019Tutor
Setting up Orbi with LTE router
I have the Orbi WiFi router. I have a NETGEAR LB 1120 LTE modem. I’ve installed a t-mobile sim. The modem is making connection. I’ve set it to bridge mode. The Orbi has brief connection and then drop...
Mar 01, 2019Guru - Experienced User
If you set the modem back to router mode and configure the Orbi for AP mode, does Orbi remain connected then?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the modem and Orbi base? Feet?
- TLI-markMar 01, 2019Tutor
I will tr that. The router and Orbi are inches apart. I connect them through the lan
- FURRYe38Mar 01, 2019Guru - Experienced User
Any wifi on the modem enabled by chance? I know if bridge mode is set, hopefully the wireless on the modem is also disabled. Having the modem too close to the Orbi base could cause problems if the wireless is enabled ON the modem.
Set LB 1120 to router and Orbi to AP mode seemed to give me a connection BRIEFLY and the Orbi is staying “white”. But the devices connected to the internet are not getting internet at this point so I can’t call it a success.
It seems all the reboots and resets have helped.
Everything appears to be holding stable at the moment. Internet speeds are not where I hoped, but they are better then the slow DSL speed I'm hoping to replace.
I'm going to let this all settle out and see where I'm at.
Thank you ALL for the great help.
Once you get into a better modem system, the Orbi will work better.
