TLI-mark
Mar 01, 2019Tutor
Setting up Orbi with LTE router
I have the Orbi WiFi router. I have a NETGEAR LB 1120 LTE modem. I’ve installed a t-mobile sim. The modem is making connection. I’ve set it to bridge mode. The Orbi has brief connection and then drop...
TLI-mark
Mar 01, 2019Tutor
It seems all the reboots and resets have helped.
Everything appears to be holding stable at the moment. Internet speeds are not where I hoped, but they are better then the slow DSL speed I'm hoping to replace.
I'm going to let this all settle out and see where I'm at.
Thank you ALL for the great help.
Mar 01, 2019Guru - Experienced User
Once you get into a better modem system, the Orbi will work better.
- TLI-markMar 01, 2019Tutor
There clearly seems to be a speed issue. Orbit was reporting 25.2 Mbps which is better than DSL 15 Mbps
but when I actual test streaming, like Netflix, I obviously am NOT getting enough speed to actual stream content. Something is wrong, but at least I seem to be getting a good connection between the modem and Orbi. Now I probably have a sim issue.
- FURRYe38Mar 01, 2019Guru - Experienced User
Maybe hitting a bandwidth speed limit issue for Netflx or any streaming.
This is a sim for a laptop. t-mobile says it is set up with unlimited data. Speed should be good. It is very possible the orbi is seeing this as a hotspot and that data speed could be limited. I’m just not sure
