TLI-mark
Mar 01, 2019Tutor
Setting up Orbi with LTE router
I have the Orbi WiFi router. I have a NETGEAR LB 1120 LTE modem. I’ve installed a t-mobile sim. The modem is making connection. I’ve set it to bridge mode. The Orbi has brief connection and then drop...
ekhalil
Mar 01, 2019Master
TLI-mark wrote:
DNS server 29.142.169.1
Lease Obtained 1Days 6Hours, 0minutes
Lease expires 1Day, 5 hours, 58 Minutes
I suggest to do the following changes (if you want you can start with step 1 only first and see if it helps alone, if not then go for step 2 later):
1. Change the DNS to 8.8.8.8
2. Change the lease time to 1 hour as follows:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the following commands:
- root@RBR50:/# config get wan_lease — Should give you --> 86400 which means 24 hours
- root@RBR50:/# config set wan_lease=3600 — 3600 means 1 hour
- root@RBR50:/# config commit
TLI-mark
Mar 01, 2019Tutor
I'm connected and holding. Orbi speed test is great. But when I use a browser on any device connected by wifi the speeds are so slow I can't even run a speed test.
I have changed the DNS to 8.8.8.8 as recommended (something I normally do)
I'm afraid I'm stuck on the telnet instructions. I have ticked the Enable telnet box, but not following the remainder of the instructions.
