Krast
Jan 10, 2018Follower
Setup Daisy Chain
I try to Setup a Daisy chain topology. The Second Satellite Connects only to the Router But Not to the First satellite.
In which Sequence I have to Start the Setup and Press the Sync Buttons?
i have the latest Firmware and Daisy chain is enabled in the Setup.
- MrX911Apprentice
I've read posts that daisy chain is not working in 2.1.1 or the latest beta either. I have 3 satellites and daisy chain does not work either
- DarrenMSr. NETGEAR Moderator
The satellite may be getting a stronger signal from the main router and is connecting to it rather than the other satellite.
DarrenM
- jmschnur923Luminary
Try moving the 1st sat closer to the 2nd and the 2nd further from the router. Then hit the sync button on the 1st sat and then the second. This worked for me.
