JamesE-uk
Apr 28, 2020Follower
Setup problem with Orbi RBK23 on a fibre system with PPPoE
In UK! Bought an Orbi RBK23 AC2200 tri-band router & 2 satellites from amazon. We have fibre internet to the house that also delivers phone. It’s from a small company called See The Light. They instal...
Apr 28, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
