hawk47's avatar
hawk47
Setup with Centurylink
I recently switched to Centurylink and I am trying to setup my Orbi router and satalites but each time I get to the part where it tells me to go to wifi settings and select the Orbi network I can't because it is not there. Any help?
  • CrimpOn's avatar
    CrimpOn
    This is a new Orbi, or an Orbi that was working on the system you had before CenturyLink?
    • hawk47's avatar
      hawk47
      I have not used it with centurylink. I use to have Xfinity but just switched today to centurylink
      • CrimpOn's avatar
        CrimpOn
        Was it set up and working with the Xfiinity, or is this a new Orbi that you are setting up for the first time?
