Harks11's avatar
Harks11
shed connection , blank sheet of paper
I have a shed 30 metres from the house. There is an ethernet cable between the two.There is an Internet connection to the house is maximum 60 meg. What is the ideal way to create a network with the one SSID. What equipemnt should I use.
  • CrimpOn's avatar
    CrimpOn
    Some additional information would be useful.  Do you have an existing WiFi system that you wish to expand?  (Orbi, perhaps?)
    60mb is an 'unusual' number for an ethernet connection.
    If there is an existing Orbi WiFi system in the house, then the ideal solution is to place an Orbi satellite with ethernet capability in the shed.
    That would be an RBS20, RBS40, RBS50, or RBS40V.
    • Harks11's avatar
      Harks11
      I have a mixture old and new but I think I need to reconsider compatability. I have a RAX80, two ex7700 and orbi outdoor. Some bad advice at the shop ended up mixing two band and three band devices. So I though I would start again and maybe get a mesh setup, but its a bit confusing
      • CrimpOn's avatar
        CrimpOn
        "Confusing" is good description of the current WiFi landscape.  Every manufacturer is (frantically) introducing products which feature
        • "mesh" (or single SSID) technology
        • WiFi6 capability (and perhaps also "mesh")
        • while anticipating WiFi6E (expanded to the 6GHz bands)
        Netgear actually has two entirely separate (and competing) product lines: Orbi and Nighthawk.
        The key question might be, "what needs to be connected to WiFi in the shed?"  Something that never moves, or simply WiFi for those times a smartphone happens to go into the shed?
        I would be tempted to drop another EX7700 in the shed and be done with it.
    • Harks11's avatar
      Harks11
      On the 60meg that is what the RAX80 says on speed test. The connection is a 50meh fixed wireless. I made mention to show its not super fast fibre
