Ken2122's avatar
Ken2122
Tutor
Oct 14, 2019
Should I correct the date/time on my router?
I just bought a new router. I am troubleshooting an intermittent problem with WiFi disconnects. I noticed under the Advanced/Administration/Log section, the date is correct but the time is incorrect (off my 1 hour). I then clicked on NTP settings and the timezone is set to GMT Bogota, Lima?
This probably has nothing to do with my problem but if I correct the timezone, will it cause any strange problems that you have encountered in the past? As a note, I have the RBR50, V2.3.5.30
  • If you have not made any settings that depend on knowing the time, then there is no urgency to make the time exact.
    However, changing the time will not cause any problem and I prefer to have the time be correct.
  • CrimpOn's avatar
    CrimpOn
