thebadpete
Jul 03, 2020Guide
Should I upgrade my firmware? I am on 2.3.5.30
Subject says it all. I have been on 2.3.5.30 and resisting to upgrade. I manually splitted my 2.4/5GHz channels so they have different SSID's, and I disabled auto firmware updates. Should I stay ...
Jul 04, 2020Guru - Experienced User
If you do choose to upgrade, manually download the FW files and install them with a wired PC and web browser:
Always upgrade the RBS first then the RBR lastly.
Good Luck.
thebadpete wrote:Subject says it all. I have been on 2.3.5.30 and resisting to upgrade. I manually splitted my 2.4/5GHz channels so they have different SSID's, and I disabled auto firmware updates.
Should I stay with 2.3.5.30, or is there any newer firmware that is as stable as 2.3.5.30?
