BAAI
Dec 15, 2017Aspirant
Simultaneous wired and wifi connection to same computer
I know it is possible to connect a computer to an Orbi satellite router simultaneously with both a wired and wifi connection ... I am doing it. But is i possible to configure the Orbi to do load bal...
TheEther
Dec 15, 2017Guru
From the Orbi's point of view, those two connections will be seen as two different computers with different IP addresses. There's no supported way to bond them together.
From the computer's point of view, you could manipulate the routing table or use some type of load balancing software to utilize both links, but it will probably will be more trouble than it's worth. It certainly won't be seamless.
