djc6
Nov 06, 2016Luminary
Slooooow iPad 3 & iPad 2 on Orbi - everything else super fast
Picked up an RBK53 - three pack Orbi at Costco on Friday. I have an iPad 2, iPad 3 both running iOS 9.3.5. They will likely never get upgraded past that, iOS 10 doesn't support them. Both devi...
- Nov 11, 2016
Hello djc6
I was able to get my hands on a Ipad 2 and test it on my orbi and I am getting the same result as you are it will not go over 20 mbs enen though my laptop is getting 70+ on speed tests I will pass this along to our engineers to see if we can find out why.
DarrenM
djc6
I hooked back up my TP-Link TL-WR1043ND v2 N300 class, 2.4Ghz router which I replaced with Orbi. My iPad 2 & 3 were able to get speeds 2x faster - 40Mbps down.
Curiously, when I use the Orbi both are pegged at almost exactly 20Mbps down like something is rate limiting it. The speedtest.net graph is a perfectly flat line that I've observed nowhere else. Still not sure why faster at uploading.
- DarrenMNov 10, 2016Sr. NETGEAR Moderator
Hello djc6
Have you made sure that the beam forming is unchecked its located in Advanced-Advanced Setup-Wireless settings try un checking that and see if this improves your connection.
DarrenM
- djc6Nov 10, 2016Luminary
Thanks for response DarrenM.
I went into settings and "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" was already unchecked.
Hello djc6
Do you happen to have any older wifi devices that connect to orbi like a old blu ray or smart tv?
DarrenM
