djc6
Nov 06, 2016Luminary
Slooooow iPad 3 & iPad 2 on Orbi - everything else super fast
Picked up an RBK53 - three pack Orbi at Costco on Friday. I have an iPad 2, iPad 3 both running iOS 9.3.5. They will likely never get upgraded past that, iOS 10 doesn't support them. Both devi...
- Nov 11, 2016
Hello djc6
I was able to get my hands on a Ipad 2 and test it on my orbi and I am getting the same result as you are it will not go over 20 mbs enen though my laptop is getting 70+ on speed tests I will pass this along to our engineers to see if we can find out why.
DarrenM
djc6
I hooked back up my TP-Link TL-WR1043ND v2 N300 class, 2.4Ghz router which I replaced with Orbi. My iPad 2 & 3 were able to get speeds 2x faster - 40Mbps down.
Curiously, when I use the Orbi both are pegged at almost exactly 20Mbps down like something is rate limiting it. The speedtest.net graph is a perfectly flat line that I've observed nowhere else. Still not sure why faster at uploading.
DarrenM
Nov 10, 2016Sr. NETGEAR Moderator
Hello djc6
Have you made sure that the beam forming is unchecked its located in Advanced-Advanced Setup-Wireless settings try un checking that and see if this improves your connection.
DarrenM
- djc6Nov 10, 2016Luminary
Thanks for response DarrenM.
I went into settings and "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" was already unchecked.
- DarrenMNov 10, 2016Sr. NETGEAR Moderator
Hello djc6
Do you happen to have any older wifi devices that connect to orbi like a old blu ray or smart tv?
DarrenM
No old devices that connect via Wi-FI. My TV and Blu-Ray are wired to a switch and switch plugs into Orbi. Both TV & Blu-Ray show up as 'Wired' when I look at Orbi interface.
Other Wi-Fi devices are 2 Macbook Pros (one Mid-2012, one Mid-2014). Both get 300Mbps via Orbi 5Ghz easily anywhere in house.
I have an iPad mini 4, iPhone 6, iPhone 6S+ - all also do very well on 5Ghz usually 250-300Mbps. Other than that, a Roku 3 via Wi-Fi and a Nest Thermostat and Nest Protect. The nest devices connect to 2.4Ghz everything - Roku and all the apple devices 5Ghz.
The iPad 2 and iPad 3 are slow (in speed tests) regardless of which Satellite I'm using or Router. I'm testing while in same room as Satellite/Router and sitting in same position where other devices which get amazing speeds.
