djc6
Nov 06, 2016Luminary
Slooooow iPad 3 & iPad 2 on Orbi - everything else super fast
Picked up an RBK53 - three pack Orbi at Costco on Friday. I have an iPad 2, iPad 3 both running iOS 9.3.5. They will likely never get upgraded past that, iOS 10 doesn't support them. Both devi...
- Nov 11, 2016
Hello djc6
I was able to get my hands on a Ipad 2 and test it on my orbi and I am getting the same result as you are it will not go over 20 mbs enen though my laptop is getting 70+ on speed tests I will pass this along to our engineers to see if we can find out why.
DarrenM
peteytesting
Nov 11, 2016Hero
just google ipad2 capped at 20mbps
it is a combination of the ipad only using 20mhz and prob only connecting to the 2.4 gig band , check what band the ipad is connected to and if the orbi 2.4 gig ch is set to auto or a specific ch as if its specific it sets the max sync at 400M
its also possible its a wmm issue , try disabling WMM in the qos
Mikey94025
Nov 12, 2016Hero
Thanks petey for pointing out that this is also a general problem seen with older ipads:
* https://discussions.apple.com/thread/2627699?start=0&tstart=0
* https://discussions.apple.com/thread/2398063?start=60
