OrbiMakeMeSad
May 22, 2020Aspirant
Slow Download speed RBR50
Another sad case of slow download speeds. This is over a wired connection. Straight from WIN10 PC to RBR50v2 (Firmware V2.5.1.8). I can plug WIN10 PC straight into the drop from the ONT and get my fu...
May 22, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Does the RBR still experience the slow down if the RBS is turned off?
Try more recent version of FW:
OrbiMakeMeSad
I updated to 2.5.1.16. Speeds when back up to 300 up and down. For about 3 hours. Now I'm back down in the 80s. Both of the RBS are turned off. Then always show good signal when on though. About 25 feet away. This isn't a wireless issue. This is a wired connection
- FURRYe38May 22, 2020Guru - Experienced User
You might contact NG support and ask for additional help with this...
