Bosie's avatar
Bosie
Slow Download Speed with RBR20
MBpsWould love some help from the community!
I have upto 900 MBps download speed from my modem (confirmed with wired connection). But when I connect it to my Orbi router and do a wireless speedtest while i'm standing right in front of it, I'm only getting about 200-300 MBps. According to the network map my iPhone is connected to the main router at 5GHz. Can anyone tell me what's going on here?
Thanks!
  • What does the speed test in the Orbi app or in the web GUI (under >> ADVANCED >> Setup >> QoS Setup >> ) give you please?
    • Bosie's avatar
      Bosie
      Thanks for the tip. I checked the speedtest in the app and found that the download speed is 403.48 Mbps which is faster than my previous test. However, it's still more than 1/2 the speed that I'm getting with a wired connection to my modem. I recognize that I should expect slower speeds with WiFi, but should the degradation be so significant?
      • ekhalil's avatar
        ekhalil
        Master
        What modem do you have? What is the make and the model please?
