plam93
Feb 07, 2020Aspirant
Slow Initial Speed then Normal Speeds
Hey All, Info: - Orbi RBK50 with 1 Sat. - Orbi router connected directly to ONT - Verizon Fios 300mbps I am having issues with consistant speeds on my Orbi. When using a device (any devic...
Feb 07, 2020Guru - Experienced User
What is the Mfr and model# of the ISP FIOS modem the NG router is connected too?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
plam93
Router Firmware: V 2.3.5.30
2000sq ft and I made sure they are within 30ft of eachother.
I have 2 neighbors next to me.
I have just tried those settings and it looks okay for now I hope it stays like this!
Thank you so much for your help!
- FURRYe38Feb 07, 2020Guru - Experienced User
Ok, make sure you don't get too much closer between the RBR and RBSs. Any closer will start to cause problems.
Please mark your thread and solves so others will know.
Enjoy.
plam93 wrote:Router Firmware: V 2.3.5.30
