Yerky
Nov 24, 2018Tutor
Slow LAN Speed
I just recently installed the RBK50 for my home internet. When I plug directly into the router and run a speed test on my computer, I average between 300-500MBps. When I unplug the Orbi router from m...
Nov 24, 2018Guru - Experienced User
What FW is currently loaded?
Try a reset on the Orbi router and this time, don't enable QoS, Traffic Meter or Access Controls.
Has nothing to to with LAN port speeds.
Yerky
Dec 02, 2018Tutor
The Orbi is connected to my Ubiquiti edge router which is connected to my Arris SB8200 cable modem. The port on the router it is connected to has no blocking service on it and was previously used by my R8500. With the nighthawk, I was only able to get consistent speeds of around 900-925Mbps. With the Orbi, it is exteremly rare to see speeds above 400Mbps.
Currently, the Orbi router is setup with no traffic metering or even QoS and the FW is version 2.2.1.210. I updated the FW to try and fix all the random internet drops throughout the day.
- FURRYe38Dec 03, 2018Guru - Experienced User
Is the Orbi system operating in Router or AP mode? If router mode, try AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
