Danmccune
Nov 11, 2020Tutor
Slow LAN/Fast WiFi on Orbi RBK33
I am getting about 50% of my availble bandwidth using the LAN port on my RBR40 Orbi Router. My internet is 1GB fiber. If I take the ethernet cable from the WAN port of the Router and plug it into m...
Nov 11, 2020Guru - Experienced User
Firmware on the router?
what ont/gateway is it connected to?
Make sure parental controls, traffic monitoring, and access control are disabled. If they were enabled, disable them and reboot the router. Then try.
Danmccune
Nov 11, 2020Tutor
Firmware V2.5.1.22
ONT: AT&T BGW210 (fiber)
Parental controls, traffic monitoring, and access control are disabled, and have always been disabled.
Rebooted and reset multiple times. I've been troubleshooting for a week with no success.
- FURRYe38Nov 11, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
https://community.netgear.com/t5/Orbi/Configuring-ORBI-RBR50-with-ATT-Fiber/m-p/1999922#M106198
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
