Danmccune
Nov 11, 2020Tutor
Slow LAN/Fast WiFi on Orbi RBK33
I am getting about 50% of my availble bandwidth using the LAN port on my RBR40 Orbi Router. My internet is 1GB fiber. If I take the ethernet cable from the WAN port of the Router and plug it into m...
Danmccune
Nov 11, 2020Tutor
Firmware V2.5.1.22
ONT: AT&T BGW210 (fiber)
Parental controls, traffic monitoring, and access control are disabled, and have always been disabled.
Rebooted and reset multiple times. I've been troubleshooting for a week with no success.
Nov 11, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
ATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
https://community.netgear.com/t5/Orbi/Configuring-ORBI-RBR50-with-ATT-Fiber/m-p/1999922#M106198
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
