McNetworking's avatar
McNetworking
Initiate
Dec 31, 2019
Slow WIFI speeds on 750/750 fiber connection
Hello All!   I wanted to post here as I called the Netgear free support line and they think that all routers (Edge Router Lite) must have WIFI and for the Orbi system, when in AP mode, none of the ...
  • McNetworking's avatar
    McNetworking
    Jan 02, 2020
    Thank you for the reply but all of the things you mentioned were tried before I posted and I even mentioned a few of those in my post. I even tested with just the Orbi router and no satellite. The R7450 still outperformed the Orbi in speed tests.
    The switch is a Netgear GS752TXP. I have since replaced the Edge Router Lite with a Netgate XG-7100-1U. The house is 3500 Sq. Ft.
    I returned the Orbi system and picked up a couple of Aruba access points.
