slow_wifi_speed
Mar 23, 2018Aspirant
Slow wifi speeds when using Orbi AC3000 (RBR50 and 2 RBS50) and Arris SB8200 Cable Modem
Hi, I have a very unique and frustrating issue which I am hoping to resolve. I don’t believe that I am the only one facing this issue so I hope my post will help others also. My current problem is; my...
Sep 17, 2018Guru - Experienced User
What are the wired speed test results after a couple of days?
What channels are you using? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Baris wrote:
HI Furrye38 and thanks for the reply.
I've continued my tests and there's a remarkable inconsitency when it comes to performance. Over the last 2 days, my wifi speed has been around 60-70 mbit/s on a 1Gigabit plan. Did a factory reset which seemed to "solve" the issue and I could see speeds up to 500-600 mbit/s, however now it's back to 60 mbit and that can't be expected..
Num1willis
Dec 16, 2018Aspirant
Did you ever get it solved. I’ve had the same problem for the past year. Inconsistent speeds.
- FURRYe38Dec 17, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001If the system was AutoUpdated, Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
