tshaw8261's avatar
tshaw8261
Slow Wifi
I installed an Orbi RBR20 wifi system and having horrible porblems w/ very slow wifi speeds.  The box states supports up to 2gig, that seems far from the truth.  I was getting 380mbps on Iphone 10, and over 640mbps on MacPro, all wireless on old Uverse box.  Bought Orbi for more range.  Barely getting 200mbps now on all devices.  This is a huge problem, as I have gigabyte service, and getting 980+mbps to modem.  Have tried all options given by so called support desk.  Sounds like they are reading from a script.  Can anyone please help, or have any suggestions.  I like the coverage, but can't keep a product that kills my speeds.  Thanks
  • tshaw8261 wrote:
    ..... all wireless on old Uverse box.  .....
    • Is Orbi in Router or AP mode?
    • Is the ISP modem/router bridged?
    • Is wireless switched off now on the Uverse box?
    • Are you using wired or wireless backhaul?
    • What wired devices do you have connected to Orbi?
    • Any difference in speed between wired and wireless devices?
    • tshaw8261's avatar
      tshaw8261
      Orbi is in router mode currently, support advised it didn't need to be in AP mode, it made no difference in speed in either mode.  Wireless radios are turned off on Uverse router.  I don't know how to bridge my router.  Just really frustrated currently.
      • ekhalil's avatar
        ekhalil
        Master
        • What types of wired devices do you currently have connected to Orbi?
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using? Try WPA2 and AES only.
