tjpug63
Feb 10, 2019Follower
Smart plugs won't connect
I just upgraded to the Orbi. I finally got the majority of my smart plugs working, IHome brand. When I tried to setup the following smart plug, Wsiiroon WiFi Smart Plug, it fails. The app, during ...
- Feb 10, 2019
This is a problem of the IoT mfr setup software. They are not considering weather the setup device can be on a 5Ghz while the IoT device only supports 2.4Ghz. Both radios are attached to the same network so it shouldn't matter which frequecy the setup device is attached too.
Try this, change the power levels on the Orbi from 100% to 25%, save and reboot the Orbi. Keeping the setup device as far away from the Orbi as possible, the setup device should then connect to the 2.4Ghz radio long enough for you to setup the IoT device. You may need to turn off the wifi radio on the setup device then back on after the power change to the Orbi router. If you can get the setup device connected long enough to complete the IoT setup, then you can change the power level back to 100%.
tjpug63 wrote:
I just upgraded to the Orbi. I finally got the majority of my smart plugs working, IHome brand. When I tried to setup the following smart plug, Wsiiroon WiFi Smart Plug, it fails. The app, during setup, wants me to change to a 2.4 network saying I am on a 5. I have tried swiching channels on the Orbi for the 2.4 wireless as recommended in another post, but it all fails. Netgear you need to update the app/software to allow the user to shut off the 2.4 or 5 wireless to resolve issues like this. I am using a Samsung S8+ with the latest android OS. I also am using Windows 10 on the computer. Any help would be appreciated.
Chuck_M
Feb 10, 2019Mentor
In the meantime, it would be nice to have a disable button (or 0%) for the wireless setup
schumaku
Feb 10, 2019Guru - Experienced User
Instead of reconfiguring everything - I don't understand why the users don't not reconfigure the network name and key/password as used on the previous wireless device, reboot all devices, finished.
- ekhalilFeb 10, 2019Master
There are devices that also remember the MAC address of the AP beside the SSID and password. I have a security camera that does this.
- schumakuFeb 10, 2019Guru - Experienced User
Very very very few do so ... and these will create issues once a mesh system (or any normal WLAN with mutliple APs) is on air - where each radio has it's own MAC address. That's a design to fail. Good luck with such garbage!
Still better to reconfigure just a single security camera than all the many dozens of IoT, mobiles, whatever ... isn't it?
- Chuck_MFeb 10, 2019Mentor
I did this on my Orbi install and I would estimate half of the devices needed to be reconfigured. It saves time tho!
