Bulhead
May 18, 2020Tutor
Smart TVs won't connect to internet
Hi I have just installed an Orbi Mesh network with RBK50s. Everything is working brilliantly and really fast apart from my 2 Smart TVs - a Panasonic and a Samsung. Both connect to the router, but not to the internet. I get 404 -Page not found errors on both.
Having looked at some discussions on here I have already disabled my original modem/router from transmitting a wifi signal, but that didn't change anything.
Any suggestions welcome.
Thanks
What modem is it connected to?
- BulheadTutor
It's a Sagemcom Plunet One Hub
Bulhead wrote:It's a Sagemcom Plunet One Hub
Thats a modem router combo device. putting you in a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
you can try placing it in passthrough/modem only mode (contact isp for help with that) or try placing your orbi in Access point mode.
