Jimmah82
Aug 16, 2020Aspirant
Solid Magenta daily drop out
Every morning I awake to find my Orbi router has disconnected with a solid magenta light. Unplugging/plugging back in or a reboot resolves the issue temporarily.
I'm on firmware V2.5.1.16. I have restored to factory settings, disabled beamforming & MIMO and it doesn't make any difference. The logs don't show anything out of the ordinary. Any ideas what could be causing this issue?
Can you please describe how the Orbi is connected to the internet?
Cable/Fiber? Provider (Cox, Spectrum, etc...) and the brand and model number of ISP device?
Is there a definite pattern to the length of time between the restart and when the connection is lost?
- Jimmah82Aspirant
The Orbi is connected to an NBN Arris CM8200 modem. I'm on a Telstra HFC plan (Australia).
The modem does not disconnect from the internet, only the Orbi drops out each day.
It's likely a 24 hour period between restart and a lost connection. I restart it each morning, it is fine during the day and early evening but has dropped out by the next morning.
- MstrbigMaster
Jimmah82 wrote:The Orbi is connected to an NBN Arris CM8200 modem. I'm on a Telstra HFC plan (Australia).
The CN8200 is a straight ISP modem, so there should be no issues there. Do you have any sort of scheduling going on? Maybe a power issue? Have you rebooted the modem? If it is losing connection close to the same time every day, it is more of a setting than the Orbi itself.
