sturner
Jul 10, 2020Follower
Solution: Xbox connected to Orbi won't play Fortnite
Hi, if you have had problems playing Fortnite on xbox or Nintendo switch which is connected to an Obri with the error message: "Checking Epic Services Queue" I fixed it the following: 1) Log in to https://orbilogin.ne 2) Advanced tab 3) Parental Controls 4) make sure Smart Parental Controls is off I also unblock any https website but I don't think this was the fix https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125# Hope this helps.
No RepliesBe the first to reply
