KryptoMagus
Aug 10, 2019Aspirant
[Solved] Case closed
Case closed because of stupid error on my end.
I was having problem with port forwarding. I have tried disabling upnp and it still doesn't work. After writing all the tests I have done, I found out that I set a static IP on the device and the gateway was set to my old router IP 192.168.1.254, instead of 192.168.1.1 I set on my Orbi.
Would be nice to know that the problem was.
Glad you figured it out though. Enjoy.
- KryptoMagusAspirant
AH good to know. Thanks for letting us know.
Enjoy. :smileywink:
