sydmat83
Aug 07, 2021Follower
Sono components not connecting over Orbi RBR50 mesh network
Hi Purchased an Orbi RBR50 router and satellite mesh Wi-Fi for our house. Mix of older and new gen Sonos components (Play3, Playbar & One). When running set up in the Sonos S2 App its finds the prod...
Aug 08, 2021Guru - Experienced User
If you do a quick search on the forums, there's a ton of issue with sonos and orbi (mesh systems in general).
It looks like something work for some but not all.
Try doing a quick search on google for sonos/orbi and try some of what has worked for some.
https://community.netgear.com/t5/Orbi/Sonos-can-t-connect-to-Orbi/td-p/1695787
https://community.netgear.com/t5/Orbi/Sonos-System-Move-Speakers-and-Orbi-RBR850/td-p/1992673
https://en.community.sonos.com/setting-up-sonos-228990/getting-sonos-to-work-with-orbi-6814829
