Masterbert
Mar 01, 2017Aspirant
SONOS & ORBI : FW V1.5.0.12 - not working anymore
since FW 1.5.0.12 - my sonos system is constantly loosing its connection - tried different seups, the only setup which works at the moment is nr 4. as soon as the SONOS players and the ORBI system a...
- Mar 02, 2017
I think any of those connection scenarios should work. Could be moving the bridge farther away from Orbi that solved it. Good luck. Let us know how it turns out.
st_shaw
Mar 01, 2017Master
I have been running with your mode 3 for quite some time with no issues.
Modem-->3rd Party Router-->Sonos Bridge 1 on Router Ethernet Port 1
-->Orbi in AP mode on Router Ethernet Port 2-->Orbi Satellite via Orbi Backhaul-->wired devices
-->Sonos Bridge 2 via Sonosnet-->wired printer, and other devices
Make sure of the following:
1) Your single bridge is the ONLY sonos device wired to Ethernet. Every other Sonos device must be disconnected from Ethernet.
2) Sonos is set to "boost" mode in the controller, NOT WiFi mode.
3) You set Orbi to use channel 1 on 2.4 GHz
4) You set Sonos to use channel 11 in the Sonos controller app.
5) You have some pyhsical separation between the Orbi and the Sonos bridge.
If you have any managed switches using Spanning Tree Protocol this can cause issues too.
Orbi has a powerful radio. I have seen it interfere with a nearby Sonos device if the channels are not separated (1 and 11). I have also seen Orbi kill another nearby WiFi access point, even though it was on a distinct 2.4 GHz WiFi channel.
Masterbert
Mar 02, 2017Aspirant
thanks for your feedback and suggestion!!
but as written above , my origin setup was ORBI (Router mode) connected to modem. SONOS bridge connected to ORBI directly --> and it was working until the new FW update, as the first issues came up, i ve changed my setup to nearly the same as your : modem ( in router mode with active DHCP) , ORBI ( AP mode) connected to port 1 and SONOS bridge connected to port 2 - but this was also not working - therefore i ve deceided to set the ORBI to router mode to get both networks separated . ( btw. SONOS and Orbi were already set to operate at channel 1 and 11 , and no other network switch is spanning trees ;-) and no other wlan interferences were detected neither by SONOS support nor by scanning the WLAN by myself)
but anyway - i made a full reset of both orbis and set them up as suggested, with ORBI in AP mode --> and its working at the moment .
the only change i made : i ve moved the SONOS bridge from close to the orbi to 1meter away.
lets see how long it is working ( as described this setup was working before....)
