Masterbert's avatar
Masterbert
SONOS & ORBI : FW V1.5.0.12 - not working anymore
since FW 1.5.0.12 - my sonos system is constantly loosing its connection - tried different seups, the only setup which works at the moment is nr 4. as soon as the SONOS players and the ORBI system a...
  • st_shaw's avatar
    st_shaw
    Mar 02, 2017
    I think any of those connection scenarios should work.  Could be moving the bridge farther away from Orbi that solved it.  Good luck.  Let us know how it turns out.
