AJMillar's avatar
AJMillar
Follower
Dec 08, 2019
Sonos and Orbi
Having struggled more than I should have to connect Sonos to Orbi wireless just posting to say that setting Orbi to AP and the 2.4Gh band to channel 6 miraculously solved the problem.  Had to power off and reinstall each speaker and reset my libary and services , which for no good reason were not connecting.  stable for now
1 Reply
  • If setting Orbi to AP mode solved the Sonos issues then that means that the ISP modem to which Orbi is connected is also a router. Usually Sonos and similar network components will have issues to work in networks with multiple routers.
    If you want to set Orbi back in router mode then please make sure to bridge the ISP router.
