Silver0066's avatar
Silver0066
Apprentice
Oct 04, 2017
Static Route Does Not Work in 2.0.0.74
See Attached.   Any suggestions?
  • as the last post states you are in the wrong area.  under advanced click on setup tab, then lan.  at the bottom you can reserve address for devices.
  • Your subnet mask is not consistent with the Destination IP address. It "probably" should be 255.255.255.255, but you'll need to first explain what you are trying to do before definitive advice can be given.
    • Silver0066's avatar
      Silver0066
      Apprentice
      I am trying to set a device on my LAN to keep its same ip address.  That device is located on 192.168.1.233.  I have already tried 255.255.255.255 and got the same results as in attachement on the original post. I can acess the destination address with my browser.
      Any help much appreciated.
