bboyd34
Aug 22, 2017Tutor
Streaming issues with Orbi
I have an ORBI router and satellite. Works great for the most part. However, two issues that creep up are streaming for Netflix and Amazon and some lag issues with my son's xbox. The router is upstai...
- Aug 23, 2017
You said your TV is near the satellite. Wire the TV if you can. I have my TVs wired. I wire everything I possibly can and reserve WiFi for devices that cannot be wired. Wired always works best.
bboyd34
Aug 23, 2017Tutor
Dang so obvious I'm ticked I didn't think of it. I was thinking you could only wire to Router for some reason. I'll try that, thanks!!!
Splunge1
Sep 01, 2017Aspirant
I have the same issue, and I am directly wired to the router. Every time I play a YouTube video or stream netflix, the video starts for a few seconds, then pauses while it buffers. Every time. This is really annoying and didn't happen with my old router. Help!
