AzJazz
Sep 17, 2017Apprentice
Streaming problems with Orbi Firmware versions v1.12.0.18 and v2.0.0.72
Hi, guys ... This community has been a great help to me, and I thought I'd pay it back now. :smileyhappy: I have had a random media streaming issue that started about a month ago. Netflix, Amazon,...
bigfellanz
Sep 17, 2017Guide
Quick Q - do you have to create a VLAN under Advanced Settings, VLAN/Bridge Settings, to connect with your ISP?
AzJazz
No, I have
bigfellanz wrote:Quick Q - do you have to create a VLAN under Advanced Settings, VLAN/Bridge Settings, to connect with your ISP?
Hi, bigfellanz - Quick A: Nope, nothing special about my connection to my ISP.. Just plug in the RJ-45 Ethernet cable, and I'm good to go. :manhappy:
- martyfpSep 18, 2017Luminary
Have you ever run the Speedtest that is built into the orbi ? Many people (including myself) have reported strange behaviour after this has been run. It seems like it initiates some form of dynamic-QoS which can cause some issues.
- AzJazzSep 18, 2017Apprentice
martyfp wrote:Have you ever run the Speedtest that is built into the orbi ? Many people (including myself) have reported strange behaviour after this has been run. It seems like it initiates some form of dynamic-QoS which can cause some issues.
Yes, I have run the Speedtest in Orbi occasionally in the past. I'm not sure if I have run it with my current configuration. I guess I will have to upgrade to v1.12.0.18 / v2.0.0.72 and erase my settings now to see if the streaming problem returns when I haven't run the Speedtest.
Another hour or so time is about to be wasted ...
