AzJazz
Sep 17, 2017Apprentice
Streaming problems with Orbi Firmware versions v1.12.0.18 and v2.0.0.72
Hi, guys ... This community has been a great help to me, and I thought I'd pay it back now. :smileyhappy: I have had a random media streaming issue that started about a month ago. Netflix, Amazon,...
AzJazz
No, I have
bigfellanz wrote:Quick Q - do you have to create a VLAN under Advanced Settings, VLAN/Bridge Settings, to connect with your ISP?
Hi, bigfellanz - Quick A: Nope, nothing special about my connection to my ISP.. Just plug in the RJ-45 Ethernet cable, and I'm good to go. :manhappy:
martyfp
Sep 18, 2017Luminary
Have you ever run the Speedtest that is built into the orbi ? Many people (including myself) have reported strange behaviour after this has been run. It seems like it initiates some form of dynamic-QoS which can cause some issues.
- AzJazzSep 18, 2017Apprentice
martyfp wrote:Have you ever run the Speedtest that is built into the orbi ? Many people (including myself) have reported strange behaviour after this has been run. It seems like it initiates some form of dynamic-QoS which can cause some issues.
Yes, I have run the Speedtest in Orbi occasionally in the past. I'm not sure if I have run it with my current configuration. I guess I will have to upgrade to v1.12.0.18 / v2.0.0.72 and erase my settings now to see if the streaming problem returns when I haven't run the Speedtest.
Another hour or so time is about to be wasted ...- AzJazzSep 19, 2017Apprentice
martyfp - FYI ... I upgraded to v2.0.0.72, and the streaming issues returned.
- martyfpSep 19, 2017Luminary
I did a "nvram erase" and factory reset, then reconfigured from scratch in 1.12 and that solved it for me. My issue was the breakup of 4k video streams, HD and below was OK but 4K (over ethernet) generally became unwatchable when there was other network traffic. My theory was that running the built-in Orbi speedest will set-up dynamic-qos which then limits bandwidth to some devices. Not running it seems to avoid that.
After doing the "big reset", I have not run the speed test and everything is fine and moving to 2.0 was Ok so far.
Hope that you find a solution....
