AzJazz
Sep 17, 2017Apprentice
Streaming problems with Orbi Firmware versions v1.12.0.18 and v2.0.0.72
Hi, guys ... This community has been a great help to me, and I thought I'd pay it back now. :smileyhappy: I have had a random media streaming issue that started about a month ago. Netflix, Amazon,...
Jul 19, 2018Guru - Experienced User
Trying to see if the NAS and DVR work while streaming thru the router instead of the satellite.
You might consider getting a non managed network switch into the mix and segment the network so you have the NAS and DVR on the same segment. Switches are good for this and help greatly.
LivinTheDream55
Jul 20, 2018Aspirant
I took Beobachter's advice and replaced it with a Velop. I'm still testing, but it looks like all of my problems are resolved.
- InnosoljimJul 30, 2018Aspirant
I’m having streaming issues with my wired and wireless set up. My Googlefiber Router has WiFi and can easily stream with all of the same devices. Firmware is updated and the issue persisted. Please help - RBR20 with two RBS20’s
- FURRYe38Jul 31, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
