mikewickens
Nov 21, 2022Aspirant
Streaming RTSP Camera local Tapo c210 on Netgear RBK53 Orbi AC3000
Hi I got some new Tap cameras C210 was trying to connect via Windows 10 PC using VLC player to Stream using RTSP but I always get a network error. I have tested the ports are open using nmap util.
Scanning 192.168.1.14 [1000 ports]
Discovered open port 443/tcp on 192.168.1.14
Discovered open port 554/tcp on 192.168.1.14
Discovered open port 2020/tcp on 192.168.1.14
Discovered open port 8800/tcp on 192.168.1.14
The Vendor guide - https://www.tp-link.com/uk/support/faq/2680/
Says to open port 554 which I have done on my Orbi router
VLC I try -
Your input can't be opened:
VLC is unable to open the MRL 'rtsp://kitchen:[email protected]:554/stream1'. Check the log for details.
I have tried many tools ispy and all fail to connect.
My ORBi is set in Router Mode as Im coming from a Virgin Hub3 in modem mode
Could this be camera is connected on 2.4GHZ and Windows PC on 5 GHZ any changes i should try to below settings ?
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- mikewickensAspirant
I fixed it did a firmware upgrade all sorted
Enjoy. 📡
