surfer_pablo
Apr 06, 2018Tutor
Super disappointed. Am I expecting too much?
I got an orbi system to deal with dead spots in our 2 BR/1200 sf condo. I did not skimp! Got a base station and a sattelite. About $400. When Orbi works - which is about 75% of the time - its a g...
surfer_pablo
Apr 06, 2018Tutor
FURRYe38 Thanks for the troubleshotting tips. I'm not intersted in messing around with the settings and I don't have time. I just want a reliable system out of the box. If I can't have that, I'd like it to at least be smart enough to tell me when there's a problem.
Apr 06, 2018Guru - Experienced User
There isnt any router that will tell you when there is a detailed problem or what the real problem is.
There is some user interaction needed. You need to find the time.
Good Luck.
