Tgterm
Oct 11, 2018Guide
Swapping Xfinity Xb3 gateway with Xfinity Xb6 and Orbi AC3000
Hi -
I just received my replacement Xfinity Xb6 Modem/Router, which will replace the older Xb3 Gateway I have been using in Bridge Mode with my Orbi Router and Sats. I was hoping someone could sug...
Oct 11, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
