bootsauce
Nov 24, 2025Follower
Sync Orbi RBS50Y outdoor satellite to new Orbi
This doesn't have enough upvotes. Thank you for the clear step-by-step. After countless hours, this was the fix that worked for me.
A couple things I'll add:
- To update firware, you'll need to download the firmware from netgear before connecting to the NETGEAR_EXT local wifi. Search for "RBS50Y latest firware extender mode".
- In the Smart Setup wizard there are 3 password options for both 2GHz and 5GHz: create new, copy router, or leave unsecured. During the first connection, select Leave Unsecured. You can change this after it's connected to the router.
Cheers!
No RepliesBe the first to reply
