agolebio
Feb 28, 2020Aspirant
Synology NAS 216+ not visible from Orbi Minirouter RBK40
Hi All, I am trying to connect Synology NAS 216+ into my home network without success. Orbi is set up as a router, there is nothing in between the ISP and Orbi. There are 3 devices hardwired (3 ...
Feb 28, 2020Guru - Experienced User
If other devices are working when connected to the RBR and the NAS doesn't and you have swapped LAN cables. Possible bad port on the NAS or it's configuration or IP address scheme doesn't match 192.168.1.###. You'll need to contact the Mfr of the NAS for support, help and additional information regarding there product.
agolebio
Feb 29, 2020Aspirant
Already raised a support case @ Netgear and Synology.
